I have a 90 tt, 108k, last week I had it converted from r12 to r134 the tec said it also had a blown 10 amp fuse on driver side wellwheel next to the relays marked air con and replaced. I drove car for 2 days and every fine work fine the 3rd day it blew warm air, so I took it back to the tec he looked at found the 10 amp fuse was blown again, he replaced and blow right away. it tried a 15 amp last about 20 seconds. I'v check the compressor clutch it moves freely if turned by hand and activates when you hit the ac botton inside. the electric condensor fan turns freely but it does not come when ac button is pushed, I was told it shound come on when the ac is tuned on? I don't know. talked to nissan tec he said to unplug the wire to the compressor and see if it blows the fuse, I found the connector but you can't get your hand in there to disconnect it! suprise. Does any buddy out there know or have had the same 10 amp fuse problems, where do I go from here, HELP! 479-244-5124
